Message 1 of 2
Multi Room Question
Sorry if this has been answered before. I have a BT pro box, if I upgrade to Multi Room and get the mini box would I also be able to use an old G4 You View in a third room or would I get the error message about extra boxes etx? I have no issues with bandwidth as I have full fibre 900mb.
1 REPLY 1
Message 2 of 2
Re: Multi Room Question
If you upgrade to the multi room you can have 2 TV boxes.  If you have your Pro, a mini and an additional box you will get a too many boxes error message.  You can cycle through the boxes and use 2 at a time.  If you move over to EE you get 2 boxes for free and can get a 3rd TV box if you pay for it
