Message 1 of 4
Multiple recordings
Hi,
I have a BT Box Pro connected via aerial. When I want to schedule multiple recordings which overlap each other, it only allows me to record three, even when one of the programmes is on the same channel that I am watching, albeit at a later time.
I thought recording via aerial was four.
Keith
3 REPLIES 3
Message 2 of 4
Re: Multiple recordings
Hi @Syrup
Are you only recording from your Freeview  serial channels  or are you recording  a mix of Freeview  and subscription  channels  (channel numbers higher than 300).
Are you setting series recordings or individual programs ?
Is this occurring  frequently  or just on one or two occasions ?
If as an experiment  you try setting 4 new individual recordings on four channels at a time when you don't  normally  record does it accept  those recording  requests  ( you can delete those requests  afterwards).
Message 3 of 4
zulu17
I tried again a couple times this morning, on both occasions it was fine, all Freeview channels.
Thank you.
Message 4 of 4
Pleased that it is working  @Syrup . Post back if you experience  again.
