Message 11 of 18
Re: My BT TV Box loses connection every night
sorry, took a while. IP addresses all present, wired connection but i have a IPC6011 error and then a YVM104 error. won't do anything until i remove and replace the cable.
I have tried every port on the router and i have also replaced the cable, first with ones i had and then one that BT supplied after i moaned about this issue.
Will be contacted them again as this is ridiculous.
Message 12 of 18
and now, while on this forum i have an IPC 6023 error come up while watching TV, meaning i am again not watching TV
Anonymous
Not applicable
Message 13 of 18
Using the steps mentioned by @Midnight_Voice previously, set a manual/static IP address. All you need to change here is the last three digits of the primary address to something below 64. So 192.168.10 for example. That will then rule out any DHCP issues. Although it does sound rather like the box is faulty.
Anonymous
Not applicable
Message 14 of 18
You haven't said which box it is but if it was supplied BT in late 2022, should be a Pro Box, unless it was a replacement?
If it is the Pro Box, have you tried WiFi? Previous boxes don't support WiFi.
Message 15 of 18
thanks. i have tried all of this with no luck.
i'm currently on a chat with BT but they don't seem to be able to do or suggest anything new, it's all diagnostic this and reset that
Message 16 of 18
hi. it is a pro box and no i haven't tried wifi, i'll do this. for some reason it did not even occur to me. cheers
Anonymous
Not applicable
Message 17 of 18
Note that you have to physically unplug the ethernet cable before the Pro Box will allow a WiFi connection.
Message 18 of 18
yup. done that now. worse. so much worse. apparently BT have done some bits and it should be better. we'll see
