Message 1 of 3
My Eurosport 2 channel keeps freezing and reporting a broadband connection issue.
Is anyone else having an issue with the Eurosport 2 channel on the BT TV box? It works for about 5 minutes, then freezes - reporting a broadband connection issue. None of the other streamed channels have this issue. The box is hard wired to the router through broadband extenders. I have reset the extenders and hub. I've checked the broadband speeds. I have also tried re-tuning the channels on the box. Eurosport 1 is working fine, which is frustrating because it doesn't show the sports that I'm interested in.
2 REPLIES 2
Message 2 of 3
Re: My Eurosport 2 channel keeps freezing and reporting a broadband connection issue.
Try changing your Ethernet cable. I had a similar issue on Sky Sports F1 and as stupid as it sounds, a cable swap fixed it
Message 3 of 3
I tried changing the leads but it still doing it.
