Message 1 of 13
NOW Entertainment Channels and the EPG
I realise that this question has been asked several times before, but I have not been able to find a reliable solution to what should be a fairly simple issue.
I have had the BT TV Pro box for about a week but the Now TV Entertainment channels are not showing up in the EPG although I can access them through the app on the TV Box. So far I have
1. Checked that no software update is available
2. Checked that there are no hidden channels in the EPG
3. Disconnected and reconnected the power supply.
I do not want to do a full factory reset as that would mean losing recordings.
As the problem seems to have been known about for over two years, I would have thought that by now there would be a fairly simple solution. Be that as it may, what else can I do to get the channels to appear in the EPG as they should?
12 REPLIES 12
Message 2 of 13
Re: NOW Entertainment Channels and the EPG
You can do a reset and keep your recordings iirc
Message 3 of 13
NigelB72
Thank you for that. I found instructions as to how to do that. However, disaster has struck. The box opens a page headed "Maintenance Mode" but then freezes and won't do anything at all. What am I doing wrong?
Message 4 of 13
By way of an update, I had an online chat with BT which resolved the problem of the freezing, but still no sign of the Now TV channels in the EPG. It is clearly a common  a common problem which should be capable of being resolved.
Message 5 of 13
So, now I have checked for a software update and re-set the box as well as waiting for 24 hours for Youview to update but all to no avail. I don't think that there is anything else I can do, so is it possible that the problem is at the BT end?
Message 6 of 13
No Now TV channels showing in EPG on my Pro box also..... tried restting etc.
Must be fault at BT end...
Message 7 of 13
Hi @shawny1967
There was a problem on our side and we have fixed it, sorry for the poor experience.
If you go to;
Settings > Software Information > Software Update
Your box should find an update and you will see all the channels in the guide.
@northshields , sorry for the inconvenience, can you please drop me a message with your account number and I will get yours fixed too right away!
Message 8 of 13
Darren,
Thank you for that. Do you want my account number here or in a PM? It's just that at the moment I can't see a way to send you a PM.
Message 9 of 13
@northshields
In a PM please, click on my name, there should be an option
Message 10 of 13
@northshields
Thanks for sending a PM, as mentioned in the PM your issue is fixed now, and you should also carry out a software update to restore service.
