Anonymous
Not applicable
Message 1 of 21
NOW TV Fast forward.
Does anyone else get the spinning disc if they fast forward a NOW program via catch up. It’s similar to what we used to get with the NOW TV logo spinning while fast forwarding. I have a BT pro box connected by Wi-Fi
Only happens on NOW app, and sometimes I get the oops something went wrong message.
20 REPLIES 20
Message 2 of 21
Re: NOW TV Fast forward.
Well @Anonymous  just tried it on one catchup programme  (U19 ICC  Final) and yes i did get that experience when i upped the FF speed
when i got the oops screen there was an error code of SDK.BUFFERING_LIMIT.UNKNOWN_REASON.MAIN_Content
(In normal viewing I don't use the FF that frequently on that app)
Message 3 of 21
I've had the same problem recently using the NOW app on my BT Pro Box connected by Ethernet cable. (The problem hasn't occurred when I have used the NOW app on my SONY Bravia.)
Message 4 of 21
Yes I have had same problem with the Now app on my T2100 box but not often.
Never seen this problem if using the Now app via the Amazon Firestick.
Darren
Message 5 of 21
I have the same issue when watching boxsets
Message 6 of 21
@Anonymous @Adz3 @ney @zulu17
I'm still getting this problem. Has anyone found a solution or know how to escalate this? I tried raising with NOW via Live chat but they said to raise it through BT.
Message 7 of 21
well regardless of whether you are billed by BT or Now the Now App is provided by Now so a technical issue with the app should be supported by them.
A billing or subscription issue should be supported by BT if you are billed by them.
This seems to be a technical issue .
Given that it seems to be an easy issue to replicate it is disappointing I will notify the moderators of this thread
As the message from the Now app says "Ooops something went wrong. That didn't work so we're going to look into it "
I think  that implies that the failures should be being logged.
Message 8 of 21
Yep I’m also getting the same issue. Only happened until recently, only fix is to return to the menu and reload the programme.
Hopefully they’ll be a fix.
Message 9 of 21
Hi @zulu17
were you able to notify a moderator?
"Given that it seems to be an easy issue to replicate it is disappointing I will notify the moderators of this thread"
Message 10 of 21
Error still occurring.
@SeanD
