Message 11 of 15
Re: NOW vs Program guide issues
Tried Ethernet with no change, these BT TV Pro boxes are a complete joke what are full of flaws, I get why people stick with Sky, even TalkTalk has dropped these boxes
Message 12 of 15
Assuming you're in contract, BT will replace it if you report it as faulty
Message 13 of 15
to be fair I only got it for the £6 offer so worse case ill just continue to use my Apple TV and enjoy the discounted cost of NOW and Netflix on there with hope Freeview brings a app for the usual channels through a guide
Message 14 of 15
The Now channels through the app will always look sharper as they stream in HD as standard, (just to be clear not Full HD). While, without the HD add on, through the YouView box they are SD only.
Message 15 of 15
@l0586
In fairness the BT Pro box is s great bit of kit and the HD quality is sharp.
You need to confirm, do you have the HD package?
If yes are you actually tuning in to the Sky News HD channel and not the SD one.  There are two SD options one via Freeview and the other via the Now SD channel on the EPG.
As I have stated previously if you do have the HD subscription then select Sky New HD channel 385, the picture quality should be sharp, if it isn't then you do have a problem.
