Message 1 of 7
Netflix Error
I keep getting Netflix error code ui-800-3 when logging in on my BT Pro TV Box, I have tried all the  suggested fixes of re-booting, signing out of Netflix (what a pain) and back in again but it still comes up with the same error every time. Exiting and re opening cures it for that session but it happens again the next time.
Any ideas it's not the end of the world but annoying and only started around the beginning of March
6 REPLIES 6
Message 2 of 7
Re: Netflix Error
The Netflix guidance for that error code is described at
https://help.netflix.com/en/node/12232
Have you tried all the steps decribed there for a set top box ?
Message 3 of 7
Re: Netflix Error
Hi
Yes I have tried all those fixes but it still happens every night after turning the box on.
Message 4 of 7
Re: Netflix Error
Does the problem occur on multiple Netflix profiles or just your own profile ?
Message 5 of 7
Re: Netflix Error
Just own profile and only BT box
Message 6 of 7
Re: Netflix Error
Well @NormanWisdom  I have no real experience in this error  so can only say what i would be inclined to do if presented with the problem. Looks like there is possibly some data on your box which Netflix App  is struggling with
Youview and hence current BT TV Boxes don't provide a straightforward methods for reinstalling individual apps such as Netflix. They do offer various levels of box resets.
https://www.bt.com/help/tv/fix-a-problem/tv-boxes/how-do-i-reset-my-bt-tv-box-
Message 7 of 7
Re: Netflix Error
Thanks I think you are right just didn't want to reset box and lose everything/ have to sign in to all the apps again, thank you.
