Message 1 of 2
Netgear Orbi 963 and BT TV
Hi
I just had Fibre 900 installed and have a new Netgear Orbi connected directly to the ONT. The broadband performance is amazing but I can't get BT TV to work (channels being delivered through the internet).
I understand multicast is needed and have the 'BT IGMP' setting enabled in the Orbi router but it's still not working.
Ive seen posts about this but can't seem to find a solution?
Tags (3)
1 REPLY 1
Message 2 of 2
Re: Netgear Orbi 963 and BT TV
First step is to connect the BT Smart Hub and confirm BT TV works with that. If there are any line/account issues, eliminate them first before trying to use different hardware.
