Message 1 of 2
New BT Box connection issues
Hi
Recently took out a new contract with BT and they sent me a host of new equipment - including a Smart Hub 2, WiFi disc and a BT Box.
Setting it all up this morning. Hub working fine - devices all connected up via wireless and a PS5 via a wired connection and all working fine.
However, I am having issues getting the BT BOX set up. Tried wireless first of all and it was hopeless - signal kept dropping out every 30 seconds making it unwatchable. So I have tried an ethernet cable and it is not picking it up at all - there is a green light on the ethernet port on the back of the box as well as a flashing orange so the connection seems OK.
On the hub manager however it says no device connected on Port 1 where the cable is plugged into.
I have tried resetting the hub and the TV box but it still won't connect through the wired connection.
I tried boosting the wireless connection using the disc I was sent but that made no difference at all.
Any suggestions greatly appreciated
1 REPLY 1
Message 2 of 2
Re: New BT Box connection issues
WiFi disc now says there is Excellent connection to TV box but says link rate is 0 Mbps?
But now I can't even get any sort of wireless connection - on the TV it says 'your box is connected to the router and the Internet ' but then literally seconds later it will lose the connection then get it back but then lose it again!!!
