Message 241 of 378
Re: New features
I have eventually got to order the new box. It was and is a long process for something so simple. They have to cancel your old multiroom that can take 3-4 working days then when that is done another 2-3 working days waiting for the new box.  So will be without multiroom for a few days . Why they cant just send it out the same day so then there isnt disruption to your viewing i do not know.
Message 242 of 378
Re: New features
Hope they can sort out additional HD channels via streaming added to the normal setup. As currently I'm recording 6 shows at once. Can't cope with just two
Message 243 of 378
Re: New features
@DarrenDev
When you say only channels 1-3 and sport are recordable are you referring to AR / EPG timings OR are there channels which can not be recorded period? Please forgive my confusion 😎
Message 244 of 378
Re: New features
All TV channels are recordable. The 1-3 and BT Sport comment only applies to the accurate recording feature. For all other TV channels, the recording will be based on the schedule.
Message 245 of 378
Re: New features
@DarrenDev- May just be coincidence, but my #465 recordings have recorded fully since switching the box to streaming mode. They were always cutting off (sometimes before the match even started) before.
Message 246 of 378
Re: New features
The issues with 465 are unrelated to this. The investigation into the Pro box reboots during matches on 433 and 465 has found a few scenarios that can cause the box to reboot or go blank screen (and not just on those 2 channels). Various fixes are being made to the box firmware, but also temporary adjustments have been made to the video encoding at our end to reduce the likelihood of it happening - this is what you're currently benefitting from.
Message 247 of 378
Re: New features
@DarrenDev
With all your knowledge about future enhancements do you think there will be a point where (as others have stated) we could see additional recording options being given for faster connections. The watch or record a maximum of two is VERY restrictive.
Message 248 of 378
Re: New features
I'm not sure @scointer - I don't know the reason for the current limit. I'll try to find out.
Message 249 of 378
Re: New features
AR on the sports channels certainly appears to be working properly. I recorded Scottish Football Extra on BT Sport 2 HD on Friday evening which I noticed started around 3 minutes before the scheduled time in the EPG, and my Pro tv box captured it in its entirety.
Message 250 of 378
Re: New features
On another positive note, has anyone else noticed how good the picture quality is on the free to air HD IP channels.  I genuinely think it is the best picture quality for the free to air channels I have seen.
I must admit, I was expecting a slight downtick in quality as the resolution is lower at 1440 x 1080,  rather than the 1920 x 1080 available on freeview and freesat.
It just goes to show that pixel resolution is not everything and good encoding, a clean source and good bitrates matter as much, if not more.
