Message 61 of 378
Re: New features
Ahhhh confused as so why mine shows zero channels 😢
Message 62 of 378
Re: New features
Did you download the update before resetting?
Message 63 of 378
Re: New features
Yes downloaded the update , then reset the box… I’ve just reset it again… went though all the rylan stuff and then it said select internet mode. Clicked that and no channels appeared and the guide says unable to show. Strange
Message 64 of 378
Re: New features
Disconnected the ariel?
Not sure what the issue is. Hopefully it will work tomorrow for you
Message 65 of 378
Re: New features
I have been waiting for this for a while as I was unable to get an antenna installed on the house due not being able to find a place where it would get signal.
Iam guessing you lose any recordings that are on the box when you do the reset?
If this works as most of you are reporting then the only thing I will be waiting for is being able to purchase a TV box for another room that an be connected via WiFi rather than Ethernet and I will be VERY happy!
Message 66 of 378
Re: New features
Hi, for those who have the update to enable IP please can you let me know the software, platform versions etc? Want to check I have the update before going through factory reset!
Message 67 of 378
Re: New features
Manufacturer software was updated as well as component software.
That's both youview and drivers.
Most likely in preparation for ip mode.
Message 68 of 378
Re: New features
@Lawiltshire can you please send me a DM with your account number and I'll check why you're not seeing any channels
Message 69 of 378
Re: New features
@WelshDave see the new pinned posts on this forum - the new Multi Room box is also available. A miniature version of the Pro box with all the same 4K HDR Atmos capability but no recording and it's IP only.
Message 70 of 378
Re: New features
exciting stuff!  I will take a look thank you!!
