Message 1 of 6
New user to BT TV
hi  am new to BT TV.
I have 4 questions.
Can I add apps to BT TV?
How did I get Discovery plus?
Can I access my sky store films on BT TV?
Why can I only record 2 programs when the booklet says I can record 4?
Many thanks
Ridgie
5 REPLIES 5
Message 2 of 6
Re: New user to BT TV
You can't add apps to BT TV but more may be added in the future so keep an eye out
You can activate your discovery plus at https://www.bt.com/sport/discovery-plus but you will need to access it through another device at present
You can't access films on sky store but you can do this through a Roku device
It looks like you have set your BT TV Pro up in IP mode, you would need to reset it through the settings menu with an ariael plugged in to record 4 channels at once
Message 3 of 6
Hi
I dont know how to reset my BT Pro up .  It was done by the engineer who put my broadband in.
Where can I get simple instructions please?
Ridgie
Message 4 of 6
Press on the blue home button on your remote
Go to the cog image on the top right hand side and press ok
Go to the bottom of the settings menu and press on factory reset
Connect your ariael to the rear of your BT TV Pro box  and click on reset on your screen.
When it reboots click on ariael mode
Follow the other on screen prompts to reset
Message 5 of 6
You will loose quite a few HD channels in aerial mode (ITV2 ITV3 ITV4, and the Channel 5 bouquet of extra channels, providing you have an aerial of course). You will gain extra channels as well, but in SD only.
Message 6 of 6
thank you all for your replies.
I will try the new settings
Best wishes
Ridge
