Message 1 of 3
No Apple TV+ HDR on TV Pro box
The Apple TV+ app is not outputting HDR10 or Dolby Vision on the TV Pro, is this by design?
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: No Apple TV+ HDR on TV Pro box
The Pro Box doesn't support Dolby Vision.
Probably a silly question, but do you have the box set to output 4K UHD? There is also a setting in the Apple TV+ app that is "limit to SD", which you should also check is off.
Message 3 of 3
Hi stereohaven
Yes my box is set to UHD 10bit with limit to SD off within ATV+. I have no issues with iPlayer, Netflix or Prime Video, it's only ATV+ that won't output HDR10.
