Message 1 of 3
No Retune Option
I have just received a BT Box. Aerial is plugged in. If I go to Settings - Signal and Connection - TV Channels it just shows TV Channels 0 and Subscription Channels 13 and a highlighted 'Done' box. I can't select TV channels and can't retune it. Any suggestions?
2 REPLIES 2
Message 2 of 3
Re: No Retune Option
Hi @Antonmouse01
In the absence  of any other advice  as it it is  newly provided  box I would suggest.
A factory reset of the box.
Then go through  the setup/install process  again.
Message 3 of 3
Thank you. I've done a factory reset and everything appears okay now. It's a pity that I'd set all my my apps up, as now I have to do them all again but at least it's up and running.
