Message 1 of 4
No return to live tv button
My new Pro box does not have the button to return to live TV after rewinding or pausing the box. To return to live TV I have to change channel and then return. I miss the button I had on the DT4000 shown with the square symbol.
Is there another method to return to live programming?
3 REPLIES 3
Message 2 of 4
Re: No return to live tv button
As far as I know its not possible on the normal EETV Pro Remote.
I have a third party remote that still has the square button on it, I'll surely test this when I get home and let you know, it uses IR and uses the same codes the old boxes used.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 3 of 4
My Panasonic remote only adjusts the volume but no other function is shared.
You can of course fast forward the EE remote to current live pictures but it can be long winded.
Message 4 of 4
So my third party remote (OneforAll) which does have Stop, Exit and Back buttons utilising IR....also cannot return to live using any of those 3, even though the IR receiver does recognise the buttons have been pressed.
I know the question had been already answered in some respect but I thought it might be interesting to test a remote that did indeed have those buttons.
