Message 1 of 4
Now TV sports package cost
Hi,
I recently paid my BT bill and it was an extra £35 for the sport package, the issue is, I had this with NOWTV which was around £20 a month as that’s what deal I had with them, however I have been now charged £35? Anyone know what to do with this?
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Now TV sports package cost
£35 is the BT price, you don't get get any Now discounts carried over when signing up.
Message 3 of 4
That’s a bit **bleep**, I didn’t wanna carry it over so to speak, just wanted to be able to use it and merge accounts and keep my cheaper rate! Might have to close it down then
Message 4 of 4
If you go direct with NOW you will get the discounted offers. If you take it on EETV you need to pay the standard price which is £34.99. The advantage is that you can record from the EPG.
