Message 1 of 5
Pixelation issues
Dear All,
I've been experiencing issues with pixelation when watching live TV and on recordings. I've had both the TV box replaced and the Hub and have had 4 engineers come round to take a look at the issue, no one seems to be able to fix it. I am streaming the TV through the Internet and there are no connection issues or network issues in the area. Is anyone able to offer some advice on how I can get rid of this problem?
4 REPLIES 4
Message 2 of 5
Re: Pixelation issues
@Georgeturp21
How's the Pro box connected to the Hub?
Message 3 of 5
It's connected wirelessly
Message 4 of 5
@Georgeturp21
How close to the Hub is the box?
Is it possible to get a long ethernet cable (Cat5e) and connect that temporarily instead of using wifi to see if that resolves the issue?
Also what speeds are you getting?
Do you have Sky Q by any chance as that uses the same wifi channel , by default , as the Pro box I think?
Message 5 of 5
The distance from the hub to the box is ~4m away.
I've bought an ethernet cable and it has resolved the pixelation issue is 99% better.
I've got no issues with the speed, 149mb downloads, 31mb upload.
I've not got Sky Q
