Anonymous
Not applicable
Message 21 of 33
Re: Problem since change to EE
@jeanjeanie2wrote:
Can you help me with choosing a new cable to use from the hub to the wall socket please? It is a minefield. Just when I think I have found one the reviews are dire. I want a good one so I can be sure it is BT compatible and in case we have any more problems
Cable to what "wall socket", mains, master socket, something else?
Message 22 of 33
A cat5 ethernet cable with RJ45 connectors at each end (such as the one below) is all you need, remember to check the required length of the cable.
This example Rhinocable is more than adequate
Message 23 of 33
Openreach MK2 master socket @Anonymous
Message 24 of 33
Thank you
Anonymous
Not applicable
Message 25 of 33
Is that a single BT431A socket or does it have the filtered faceplate with a separate RJ11 connection for the broadband?
The cable that @Les-Gibson posted won't be suitable in either case.
Message 26 of 33
Yes, the telephone cable is at the bottom and the broadband at the top thank you
Message 27 of 33
Hi @jeanjeanie2 we should be able to get a new cable sorted for you - sounds as if you have a MK2 socket similar to this one - is that right? It's probably got a black cable with grey ends running from there  to the DSL (Broadband) socket on the back of the hub.
thanks
David
Message 28 of 33
Spot on!
Message 29 of 33
@jeanjeanie2
@Anonymous is wrong.
Your TV box connects to one of the LAN sockets on your hub, not directly to your line
Message 30 of 33
Very grateful
