Message 1 of 2
Programmes overrunning ..
Programmes Overrunning
Hi, does anyone else have problems when recording - the end of programme is missing? I’m getting so frustrated, the end of more and more programmes are missing and it means we are left not knowing what happened.
Is there anything we can do in a setting to make this change? We need to stop it!
TIA
1 REPLY 1
Message 2 of 2
Re: Programmes overrunning ..
@TJHRAH120981
Nothing in a setting that I know of.
if you can do it without clashes, record the programme following the one you fear will be cut short. As the changeover is near instantaneous, you should find the end of the truncated programme at the very start of the recording of the next programme.
This will work fine for individual programmes, but you may have issues with Series recordings, unless the programme following the Series one is a further predictable one.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
