Message 1 of 6
Radio stations red button
The radio stations work fine via the sounds app but if you use the TV guide don't load using the red button ?
5 REPLIES 5
Message 2 of 6
Re: Radio stations red button
@Jogon  are you using a Box Pro in Ip Mode  or a different box or are you in aerial mode on the box pro .
Also do you see the Press red to listen appear  or does it not appear .
Message 3 of 6
Pro box in WiFi mode ...
See red button option but it does not kick in .
Message 4 of 6
If convenient suggest soft restart the Box Pro. (Hold front button for about 8 seconds and it should restart.) When restarted  try again and see if red button functions.
Message 5 of 6
Many thanks that did the trick 🤜🤛
Message 6 of 6
No worries thanks for raising and reporting back  that helps others in future if they have similar issues
