Message 1 of 3
Re: EE TV Box Pro issues
I have been having problems with my EE Probox since last year when I was forced into replacing my BT Probox at contract renewal.
The  BT Probox did not give me any problems. Since having the EE Probox  they have replaced the box  and reset the software twice and it has made no difference. I have been told by BT that the guts of the BT  box and EE box are the same but I do not believe it. At this time  BT have sent a letter to me suggesting I contact the communications ombudsman.  Having been with BT for many years I am now thinking I need to change to Sky because I am sick of constantly not being able to wind recordings back or forward without problems .
2 REPLIES 2
Message 2 of 3
I can assure you, the insides are the same - the only thing that changed was the case that it came in.  A TV Box Pro wouldn't normally be swapped on contract change - they'd just say to keep the one you have.  Not sure why you were forced to swap, but you would still have had the issues you're experiencing with the box you had before.
Given that your TV Box has been swapped already to try and resolve the fault, the issue is more likely to NOT be the box itself. e.g. looking at your broadband connection, I can see data occasionally being lost - sometimes it's just for short periods of time, and sometimes for a few days (e.g. 12th to 15th of April, it was quite bad).  If the recordings you're trying to rewind are from internet channels, then this could be the issue.
If the recordings are via your TV aerial, then it could be an issue that has affected your aerial strength since the swap. Maybe snow moved it? Or a building was completed nearby that degraded the signal? Or maybe even just the act of changing the TV box has dislodged the aerial connection a little.  It's also been known for power supplies to cause issues - when you received the replacement TV box, did you also use the replacement power supply that came with it?
There are many different factors that could affect this, and they should all be investigated to find what's causing your specific issues.
Message 3 of 3
Thanks for your reply in April. You probably noticed that I have not previously replied. There is no problem with the aerial and the new power source has been used. It is interesting to note that since EE/ BTrecently did a software update that several customers including myself no longer have any of the problems that we were experiencing . Let’s hope that the problems that we had will not return on 15th October 2026 when we return to BT
