Message 1 of 26
Re: Keep Youview Box
Am in the same situation as yourselves. As a want to keep the Box & would happily pay the £115. As everything runs through my internet. As have no Aerial. Surely rather that recycling it would be better for them to have the £115. A honestly don t no what to do
25 REPLIES 25
Message 2 of 26
Hi there
Just saw this pop up and I do sympathise as my mom was really hesitant to lose the box. One thing I would say is have a look at the "manhatten" boxes if you do end up having to return it as those look pretty good!
Hope that helps!
Message 3 of 26
Sure will.  Thanks 👍
Message 4 of 26
The channels will only work via bb with no aerial if you have a EE tv subscription though, if not it will be useless basically
Message 5 of 26
A understand that. But am getting all through my internet plut on demand freeview channels. If I got/took out a BT TV basic before 2019 (which I did), it was BT you sent me the new BT BOX, So where do I stand in this situation folks.
Message 6 of 26
A still have BT BROADBAND taken out till August 2027. So it s a great help to me, plus been with them BT for years!!
Message 7 of 26
So any answer's to my query folks!!! Be glad to here from someone
Message 8 of 26
Look folks a think a have a solution to those who are keen to have there BT TV BOX. BT You iew+ Set Top BOX with Twin HD Freeview and 7 day catch up TV.÷ NO SUBSCRIPTION. Brand New÷ £132.98. From Amazon plus a Remote at £7 if needed. As was looking up there & it is the exact same box as I have. So if your going/don,t want any hassle, just order this and sent your old one back. An extra what for Remote & all say £25. That,s the best I can see for those like myself who might have to hand there,s in. Think about it. 👍👍👍
Message 9 of 26
Hi @rodders241
Have you actually been asked to return your TV Box and been warned that a non return charge of £115 will be applied if you don't or are you simply making deductions from other peoples comments on this or other threads.
The normal BT charges are currently listed in their tariff guide
When you end the EE TV service you must return the EE Set Top Box that was loaned to you, within 60 days from the date the service is terminated. If you fail to do this then you’ll have to pay £60 for a BT TV Box (Z4), £75 for a BT Box Mini, £75 for an EE TVBox Mini, £89 for a BT TV Recordable Box (G4), £115 for a BT TV 4K Recordable Box (G5), £140 for a BT TV Box Pro or £140 for a EE TV Box Pro.
this page https://www.bt.com/help/tv/learn-about-tv/bt-tv-boxes
has images of the BT (EETV) - do you see your current TV box there and which model is it ?
I had a quick look at Amazon and my imprression is that the item you are considering as a like for like replacement is a BT TV Recordable Box (G4)
So if you currently have that box the non return charge should be lower at £89 and not £115.
At one stage I do believe BT supplied replacement boxes to those on legacy contracts who  were using the original first generation T1000 for which support  and Youview functionality was withdrawn.  Was this how you got your current box ?
You also mention that you don't have an aerial connection to your BT/EE TV box so if that is the case you would not  have the Freeview channels available to view and record on your BT/EE TV box. Only the BT/EE TV Box Pro has the FreetoAir channels available in IPTV mode to watch and record from the Box EPG (guide) so if you have  either a BT TV Recordable Box (G4), or  a BT TV 4K Recordable Box (G5)  with no aerial you will only have subscription channels such as TNT Sports  and possibly some Entertainment channels in the EPG to watch and record. If you end your EETV package your subscription channels and their recordings are no longer viewable. Apps such as they are on the box would be viewable some have free content , some have subscription content for which you would need to subscribe.
We are already seeing apps being withdrawn from the BT/EE TV boxes particularly the older models  so you should consider whether buying older models is really the best investment.
Message 10 of 26
That,s the box I have then from BT, Which they give me in 2023, a think. But am getting all freeview channels no bother plus 5 BBC 1, 2, ITV, Ch.4 & Ch.5 in HD. No bother
