Message 1 of 3
Recorded programmes drop out before end of programme Youview box Item080753
2 REPLIES 2
Message 2 of 3
Re: Recorded programmes drop out before end of programme Youview box Item080753
Hi @pitullie
YouView use a system called AR to control when Freeview  programmes recording start and stop
The idea is that the broadcaster will make these times exact in its broadcast transmission signals.
But it is not mandatory for channels to do this so if they don’t the recording will default to the timings shown in the EPG.
So the lesser channels tend to use the EPG times, and not quite stick to them.
Message 3 of 3
@pitullie
As @zulu17 mentions there are certain lesser channels that have issues with AR and if you find it's a specific channel/programme then one solution is to always record the following programme.
The inability to add padding or set your own timings is probably the most complained about non-feature since Youview's inception. Never going to change now I'm afraid.
