Message 1 of 5
Recording BBC Radio 4 Programmes
Hi All
Im sure it’s me doing something simple wrong but….I’d like to be able to record some of the BBC Radio 4 comedy shows that are usually on at 6:30pm (weekdays) … I go to Guide, Blue Button, along to Radio, select the programme and press record …. All I get is a message saying “This programme can’t be recorded, Please try again later”
Any suggestions welcome
4 REPLIES 4
Message 2 of 5
Re: Recording BBC Radio 4 Programmes
Use the get_iplayer utility on your laptop. Its what I do for BBC radio programmes so I don't have to use the godawful BBC Sounds app to listen to them on my mobile phone.
Message 3 of 5
I record several radio programmes every week. Some are on series link and others I set up as individual recordings via the guide. Our Pro tv box is connected by aerial mode and I’ve just done a dummy run to record a programme on Radio 4 @ 6:30pm on Monday using the method that you described and it set up the recording with no problems.
Message 4 of 5
If your box is set up in IP mode i.e. with no aerial connection, that may explain why you are unable to set up radio recordings from the guide.
Message 5 of 5
@Brucemeister5  The message you would get if in Ip mode on a TV Box Pro is different.  It is a simple. “Sorry ,BBC Radio 4 can,’t be recorded because it’s a radio channel”
@Kap220  is receiving a different message.
