Message 1 of 2
Recording Programmes and Series Links
Hi,
We have just switched from Sky
Is the only way to record programmes and series links by using the tv guide
Is there any way of using the search function and saving programmes and series to MYTV  then setting up a record function  from there ?
Many thanks
Mark
1 REPLY 1
Message 2 of 2
Re: Recording Programmes and Series Links
Hi @markw64
You can set recordings in various ways.
So for example if you use the Search  facility you will the  get search results returned.
So for example say if you search for Frasier the result show’s initially how Frasier can be watched On Demand . However a second tab on the search results screen  On Now and Later shows upcoming episodes on the linear channels. Selecting  an episode and pressing the Record button on the remote will schedule that episode to record and offer you the option to record the series.
You can also set recordings using the Now and Next tiles.
You can also set up recordings for current  channel programming on the home  page using the Record button.
You can also set up recordings for the current programme being watched by pressing the record button.
Using the BT TV app on a mobile device paired to your BT TV box also allows you to select and schedule recordings.
(The record button on the remote is also used to add  or remove ON Demand content to  or from your watchlist. )
