Message 1 of 3
Recording stops before end
I have a new EE box. The recording of Television programmes stop before end of the programme. So annoying does anyone else have that issue. What can I do?
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Recording stops before end
Edit fail, please ignore.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 3
@carsonbriggs66
Everyone, and nothing.
Except that if you record the following programme, the missing bit will be at the start of it.
Search the Community for Accurate Recording, as this is laughingly named.
Do you have examples of affected programmes, each with some indication of how much is cut off?
What EETV device are you using, and is it in Aerial Mode or IP Mode?
