Message 1 of 8
Recordings show as recording but are 0 secs long
Programmes which show up as recording are zero secs long when replaying. All has been fine until this last week.
7 REPLIES 7
Message 2 of 8
Re: Recordings show as recording but are 0 secs long
@Ylyurga
What device?
if a Box Pro, then try Settings/Factory Reset/Factory Reset (Keep Recordings).
If the issue continues though, then you may have disc corruption, which will need a full Factory Reset 😢
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 8
Thank you. The programmes have appeared without the reset and they are fully recorded. Wierd.
Message 4 of 8
@Ylyurga
Keep your eye on it, maybe even try that reset, keep recordings. What you are seeing - both the disappearance and the reappearance - are symptomatic of index corruption.
Message 5 of 8
@Ylyurga  may I ask whether  this issue occurred  only when deciding  to play a recording  that was currently recording on the box , ie the recording  was still in progress or whether  it also occurred  on recordings already completely ?
Message 6 of 8
It did occur when looking at a recording that was still recording. It has never been an issue before.
Message 7 of 8
Thank you.
Message 8 of 8
Morning @Ylyurga
Thanks for coming to the community.
Please let us know if this happens again with the recordings.
Have a great day 🙂
Leanne.
