Message 1 of 3
Remote clash
I have a freesat box as well as a freeview box.
The freesat remote is well-behaved and controls only the freesat box.
The BT freeview remote however controls both boxes (all functionality).
I can change the remote frequency on the freesat box, but the BT remote still controls both boxes.
The BT box / remote does not appear to have any settings for the remote->box connection.
Is there any way around this?
Tags (3)
2 REPLIES 2
Message 2 of 3
Re: Remote clash
Hi, having the exact same problem. Did you manage to fix it?
Message 3 of 3
Re: Remote clash
I re-paired my BT remote with the box and now I have independent control over both boxes. Might be woth a try.
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr...
