Message 1 of 2
Remote control issues
Hi, I’ve been with BT for 7 years and my equipment is so slow and dated. My remote has not lost some functions, such as the down arrow not working.
Firstly, any suggestions with a remote that doesn’t fully work?
Secondly, will BT provide new equipment to existing customers or is this only to new customers?
thanks in advance
1 REPLY 1
Message 2 of 2
Re: Remote control issues
@Sparks89
BT will give you a new Box Pro if you ring up and ask, likely a Box Mini as well, though they may want you to renew your contract.
As your existing box is more than 7 years old (dates from before 13 December 2019) it’s yours to keep, even if BT send you a returns bag; you don’t have to return it.
Replacement remotes are freely and cheaply available from a site named after a well-known South American river.
The buttons can fail physically on old remotes, but you could try a reset, depending on exactly which remote it is:-
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr....
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
