Message 1 of 7
Resuming live TV
How do I resume live tv after pausing with BT TV Box Pro?
6 REPLIES 6
Message 2 of 7
Re: Resuming live TV
Press and hold fast forward until it catches up
Message 3 of 7
If you don't want to watch what was showing between when you paused the TV and when you want to resume watching just press the "stop" button and it should return you to live TV.
Message 4 of 7
What stop button? There are fast forward and rewind buttons with a pause button in between. There is no stop button.
Basically, as mentioned above, you have to fast forward until you catch up. It's the clunkiest system I have ever seen.
Message 5 of 7
It would appear it depends on which remote control you have.
Which remote do you have? | BT Help
Going by what you have said I presume you have the one on the far right.
If you are watching a pre-recorded program and decide to stop watching it what button do you press?
If there is not a specific button try pressing the button for the channel number you are on.
Message 6 of 7
Thanks. A real downside give the previous box and remote had that function.
Message 7 of 7
Agree!
