Message 1 of 2
Series recordings
Why can’t I do a series recording on Alibi for Bookish or My life is murder
1 REPLY 1
Message 2 of 2
Re: Series recordings
@Vaboon  this is because there is no series Crid present in the guide which links the episodes of those programmes  into a series so you are only offered the individual  episode to record.
So a data ommission which could be due to the broadcaster data or the process whereby the data reaches the EPG on the EETV box.
EETV have some current  issues with the data suppliers so until this changes you will need to set individual  recordings is no series  option is offered.
