Message 1 of 6
Smart TV, BT Youview box and Roku Express
Hi. I have a Samsung Smart TV that I have connected to my BT Youview box. While the box has some apps on it (it’s about 7 years old), I’m missing some I want to access. So I bought a Roku Express stick.
I want to watch TV and stream stuff through my Roku stick, but keep the BT box so I can record programmes.
Problem has arisen that while this all seems to work, I find that the sport I am watching through SkySports on NOW (on my stick) is a bit jerky - picture doesn’t seem smooth - and I encountered a buffering issue while streaming from BBC iPlayer. Note that I have fibre broadband which is very fast.
My question is: do I need to switch off the BT box when I am streaming through Roku so I am not overloading the broadband? If so, should I just use the BT box as a recorder direct from my Smart TV? And if so, I guess I need to connect things up differently.
Any advice or pointers welcome.
David
5 REPLIES 5
Message 2 of 6
Re: Smart TV, BT Youview box and Roku Express
You might be running into a bandwidth issue. What is your broadband speed?
Message 3 of 6
Thanks for responding Nigel. I’m on BT Broadband Fibre 2. Advertised speed is 67-73 mbps.
Message 4 of 6
If you're streaming HD or higher while trying to record a couple of IPTV streams, you might run into issues especially if you have NowTV HD Boost.
Message 5 of 6
How are you powering the Roku stick? if from the TVs' USB port and the TV is 7 years old then it could be that the USB port is struggling to supply the necessary power.
It's easy enough to prove or eliminate that, just power it from a 2A phone charger and see if the problem stops
Message 6 of 6
Thanks both. I’ve changed the power source and will see how that goes.
