Message 1 of 3
Subtitles on BT TV advice /
Hi, looking for some advice/info please.  My elderly father relies on subtitles for most if not all TV watching.  We are thinking of moving to BT from Sky Plus.  Can anyone advice if the subtitles are easy to read on screen?  We are so use to Sky and they are quite large in font on our 32 inch tv.
Also is EE TV easy to navigate and is recording programmes simple? Having been with Sky for so long and use to their set up it would be helpful to know.  Many thanks
2 REPLIES 2
Message 2 of 3
Re: Subtitles on BT TV advice /
The subtitles on the broadcast and subscribed channels are large and clear.
Those in some of the apps (such as Netflix and Now) can be different sizes, but most are good.
The Programme Guide is easy to follow and setting recordings just a press of the record button - if it is a Series you get asked if you want the series or just one recorded.
To get to your recording list, you press the Home button and then the down arrow twice.
I find it easier than the Sky menu system, but I have used it for quite a long time.
Richard
Message 3 of 3
Many thanks helpful.
