Message 11 of 15
Re: Subtitles on Youview
@Midnight_Voice  I suspect  it is because  the players  eg IPlayer/4 do not recognise the More button function  whilst they do the Delete/Subtitle button function.
When watching EPG channels....When you do use More button   on the Pro Remote  you may have to navigate  left/right and  you will need to press a further OK to effect switching subtitles on/off.
Message 12 of 15
@zulu17
Duh - I was assuming that More just got you to a submenu where you would choose Subtitles and then make the setting.
Are you thinking @Jeceris wasn’t doing that?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 13 of 15
Thank you for the comments. I am more than happy to use the old remote with the Delete/Sub button along with the Pro box. It's a one click solution as opposed to the tortuous alternative.
Incidentally after talking to a BT Guide, I used the new remote to navigate from the Home button across to the Settings cog, scrolled down to Accessibility, selected Subtitles on, then Done. Result - no subtitles!!
With the old remote it's on/off at the touch of a button.
Case closed.
Message 14 of 15
@Jeceris
It looks like maybe Up Arrow on the Pro remote (and even the older remotes) may be a common thread for reaching subtitles?
Message 15 of 15
That may be the case, but after that the procedure seems to vary depending on the app.
Hard to be sure about things when some programmes don't seem to support subs so you don't know whether it's the box, the remote or the programme you're watching. I've given up experimenting and will rely on the good old DEL/SUB  remote and hope it will continue to work.
