Message 61 of 70
Re: T4000 Fault causing Power-Down ...
They are both the same model box T4000. It happens with both recorded programmes and live ones. This is usually if the fast forward is repeatedly used. It is more prevalent when using step forwarded. I happened six times in succession the other day. I’m almost ready to abandon the box altogether. I’ve been with BTTV since its early days without any problem until now.
Message 62 of 70
Thanks @Docburl, which channels have you been noticing this with?
Peter
Message 63 of 70
Watching programmes days later. ITV HD and Sky Arts.  You press the button to skip forward and you get a fraction of a second on noise and a sound from the hard drive.  Then you switch the box back on an you get all the Youview screens like you would after a full restart.
Message 64 of 70
this  problem is still occurring , and 2 days ago it was ridicules it must of shut down 10 times in 2 hours just by pressing ok  but today  is has only done it twice  . i did online chat a while back about this and the operator said he will send a new box even though i said not too he also reset my bb and now my bb has gone down 18meg and will not go back up
Message 65 of 70
Hi @welshgit
I am sorry this is still occurring, I would advise getting back in touch with our technical support guides and they will run through some troubleshooting with you to see what the next steps will be to get this sorted.
Leanne.
Message 66 of 70
sorry if this sounds like a rant ,its not its just my observation .....the only way a replacement box will work correctly during the day  is by not connecting to the internet over night or turning it off at the back to stop it from doing automatic updates . its a firmware problem . i have already tried all the resets with the last guy but all to no avail . Why he thought a bb reset would make any difference i have no idea
Message 67 of 70
Thanks for coming back to me and I understand your frustration @welshgit
If you could get back in touch the team will get this looked into in more detail for you.
Leanne.
Message 68 of 70
Was this problem ever officially resolved and closed - I have avoided any COM5 Channels, so havent had a repeat ..
Message 69 of 70
Can a Moderator or a visiting Specialist please advise if the COM5 issue addressed earlier in the thread by @DarrenDev - is actually resolved & closed ?
Many Thx ..
Message 70 of 70
I bit the bullet & recorded a COM5 Channel - FILM4+1 Prog last Night - no issues using Fast Forward & 'Jump Forward' thru the Advert break - so m a y b e the Power Off problem is fixed ?
Would have been nice to get a response tho ...
