Message 1 of 14
TV Box Pro and WiFi
Has the BT TV box pro had its Wi-Fi ability disabled?
A  year or so ago I used to connect this TV box via Wi-Fi but after having some unrelated issue (which I can’t remember the details of) I “temporarily” connected it via ethernet cable
I now find myself needing to free up an ethernet port on my router. However, when I try to connect my TV box via Wi-Fi it fails every time. I have tried the WPS method and also the scan method. The scan finds my network but will not connect.
I was just wondering whether this box is somehow no longer Wi-Fi capable.
Tags (2)
13 REPLIES 13
Message 2 of 14
Re: TV Box Pro and WiFi
No - nothing has been done to disable WiFi.
What router are you trying to connect to? Is it the one provided by BT?
Message 3 of 14
Yes it’s my BT router. A Smart Hub 2.
Message 4 of 14
Have you made any changes to the WiFi config on the smart hub 2?
The best suggestions I can make are a reboot first, then a factory reset of the hub if the reboot doesn't work.
Message 5 of 14
Personally, I've never had much success using my BT TV Box Pro in wi-fi mode, even since I was upgraded to full fibre last month. Just too many drop-outs and glitches (pixelation etc.). Problems which don't affect any other devices connected via wi-fi in the same location (TV, Roku, blu-ray player etc.). So I soon switched back to a wired connection for a much more stable and reliable connection.
Message 6 of 14
My suggestion is to add an ethernet switch to your router giving you many more free ethernet ports you can use.
Message 7 of 14
I only need one 🫤
Message 8 of 14
But you said that you needed "to free up an ethernet port on my router", suggesting that they were all in use?
Message 9 of 14
Hi,
Yes, they're all taken and I just need one more. Getting the TV Box to use WiFi would free up a port and solve my problem.
Message 10 of 14
Would any of the other devices connected to your router work ok via wi-fi instead?
Like I say, I find the TV Box the least reliable over wi-fi which is why I still have that connected via cable whereas the smart TV, Roku box and blu-ray player (all in the same location) work fine over wi-fi.
I actually have my TV Box connected via a powerline adapter as the router is in the hall (another reason why the wi-fi is less reliable, although it's fine for any other device in the living room).
That could be a solution for you as well, as you can get some powerline adapters with more than one ethernet socket. I have one with three so I could connect three devices by cable at the other end (although I now only have the one, as I tried doing away with the powerline adapter altogether until I discovered that the TV Box just wasn't performing over wi-fi).
