Message 1 of 3
TV channels in guide
After setting up my new TV box first on internet and then trying after a factory reset to use the aerial, I only get about 20 channels and none of the normal BBC or ITV. My aerial is a little weak but it worked better straight to the TV. Is the new box sensitive to the signal strength. I also don’t see any other channels like NowTV I need to go to the app. For these so can’t record.
2 REPLIES 2
Message 2 of 3
Re: TV channels in guide
Try forcing a manual software update from the settings menu, that usually resolves the EPG problem (even if you are confident that you already have the latest software)
Message 3 of 3
Brilliant, I’ll give that a go.
thanks
 Ted
