Message 1 of 7
TV will not pause, rewind
Hi, I am new to the BT TV and have a Pro box.
I do not seem to be able to pause, rewind this is on any channel.
Does anyone know how i can resolve this issue please. I am sure it is an easy fix but I am unable to find an answer
John
6 REPLIES 6
Message 2 of 7
Re: TV will not pause, rewind
All sorted.  for those that know I used the ID-10-T switch 😂
Message 3 of 7
Hi there @Scientist
Thanks for popping back and letting us know you sorted this.
Have a great weekend.
Leanne.
Message 4 of 7
Would you care to share what you did wrong @Scientist , just in case anyone else is having a similar brain fart? 😃
Message 5 of 7
@DarrenDev You just want me to look more foolish than I felt. 🤣🤣
Working in IT as I do. I forgot the first thing to try. 🤷🏻‍
And that is, turn it off and reboot the box.
Message 6 of 7
OK, that's interesting - it shouldn't have needed that, but yes, a reboot is always a good first thing to try.
I actually thought it was going to be worse than that - e.g. using the wrong remote control! I know some TVs have FFWD and RWD buttons on them, which I'm sure could confuse some.
I'm glad the fix was really simple.  Thanks for updating.
Message 7 of 7
I do have the remote with FFWD and RWD buttons, they did not work either.
