Message 1 of 5
That's 70's Music
Hi, can't seem to find "That's 70's" channel though I can get "That's 80's".
Thx
Tony
4 REPLIES 4
Message 2 of 5
Re: That's 70's Music
Channels 71 and 75 respectively. Are you in IP mode on your Pro box?
Maybe 75 is available that way, but not 71, which you would need to go back to aerial tuning for?
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 5
@Midnight_Voice these channels aren't currently available in IP mode.
@Flipflop96 there are sometimes issues with IPTV online channels with youview channels with an ariael plugged in.
Hopefully they sort these out.
If you have the BT TV Pro, a work around would be setting it up in IP mode by resetting with the ariael disconnected from the back of the box and using Freeview built into your TV (trusting that your TV has Freeview built in) for this channel and the channels that arent available in IP mode.
A current list of the available channels are at: Internet mode free to air channel guide | BT Help
Check the list to make sure you would not miss out on recording any channels that aren't currently available and you can currently only record 1 channel and viewing another in IP mode, although I have seen that they are going to work on this to see if you can use more tuners.
Anonymous
Not applicable
Message 4 of 5
There was a recent channel change for these. 60s should be on channel 65, 70s on 71 & 80s on 75. But I noticed on my Mum's TV that there's issues. 60s is fine but 70s & 80s  are listed in the EPGs but don't play. Just tried both the Samsung TV & Pro Box, so looks like an issue with the ARQ B MUX.
This is from the Sudbury, Suffolk transmitter.
There was a similar issue a while back again featuring an ARQ MUX that was fixed by reporting to the YouView forum. That sadly no longer exists.
Message 5 of 5
That's 70's is a part time channel (0400-0600) on Com 6, sharing with That's TV.
Freeview timeshares (xhxf.uk)
The station does stream on channel 71 outside those hours, but it depends on your Smart TV whether you can view it. Generally if you can view Channelbox on channel 271, (which by the way streams Now 70's, 80's, and 90's), then you can probably view it through the red button (wait for the slate to appear), though it still can be hit and miss on many TV's. As for the Youview box that's a definite no.
