Message 11 of 20
Re: Timing issues
@Suebedoo
I can’t, I’m afraid, the Community rules wouldn’t permit that 😢
But open a new tab on your browser, type Manhattan T-4R, and see what comes up.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 12 of 20
Re: Timing issues
Ok - thank you
Message 13 of 20
Re: Timing issues
Hi
Many thanks for your ongoing comments on this issue. I didn't understand what you meant by a remote app?
Nigel
Message 14 of 20
Re: Timing issues
There’s an EETV app which enables you to set up recordings by linking your tablet/phone to your box. It’s possible to watch a limited range of channels via this app too.
Message 15 of 20
Re: Timing issues
@nigelf1234
With the YouView boxes, you can have the EETV app on a mobile or a tablet, pair it with a YouView box, and set the box to record remotely, from the app, even if you are hundreds of miles away.
I see that Manhattan now have things you can do from a browser, though I haven’t investigated exactly what they are, but it only works if you are on the same WiFi as the PVR, so not fully remote like YouView.
Message 16 of 20
Re: Timing issues
Hi
Many thanks for that. Didn't know such a thing was possible!
Message 17 of 20
Re: Timing issues
I have a Manhatten T-3R and is is excellent. As well as allowing padding to be added to recordings, it also allows fast forwarding through the ads on all its recordings, something that I understand the EE boxes now don't allow, at the behest of the advertisers.
Message 18 of 20
Re: Timing issues
@chrisjp
To be exact, you can’t fast forward through the recorded ads on the itv channels on a Box where the recordings were made in IP Mode. Recordings made in Aerial Mode do not have this restriction.
It’s also true that if you make a recording of a BBC channel in IP Mode and try to play it back, the BBC treat this as an invitation to play it back to you on the BBC iPlayer, and not from the actual recording you made. Playback is also conditional on the programme being available on iPlayer at the time you try to play it back. Again, recordings made in Aerial Mode do not have this restriction.
Both of these restrictions are at the behest of the broadcasters, not of the advertisers.
Message 19 of 20
Re: Timing issues
@nigelf1234
Indeed - just as long as you have paired the EETV app and the YouView box as a one-time procedure while you are physically in front of the box, you can now get recordings cut off before the end from recording requests made not just in the comfort of your own home, but from anywhere in the UK where a mobile or WiFi signal is available 😛
Message 20 of 20
Re: Timing issues
Hi
Just to say I have a Manhattan T4-R which has resolved the timing issues & am very pleased with it
