Message 1 of 6
Two Remote Controls
Coming from Sky Q we was able to have two remote controls, onw for the wife and one for me. Is it possible to have two remotes on bt tv pro box ?
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: Two Remote Controls
The supplied remote is bluetooth so I'd be surprised if two could be paired simultaneously. But the Pro Box also has an IR receiver that responds to previous generation remotes using the Humax code set. So one of these or similar should work as a secondary remote.
Message 3 of 6
Where is the infared receiver on the box? As we have it hidden it doesn’t pick it up but I have an infared extender but this needs to be in sight of where the infared point on the box is.
Anonymous
Not applicable
Message 4 of 6
Roughly half way between the centre "BT" button & the right hand edge. Around the Status LED.
Message 5 of 6
@Anonymous
Essentially as long as the older remote control (for Z4, G4 and G5) has 'line of sight' with the F1 Pro Box, it should work.
Anonymous
Not applicable
Message 6 of 6
@PhilipL790wrote:
@Anonymous
No idea what relevance that has to the question I was answering?
