Message 1 of 4
Utv app not opening
For the last couple of days have not been able to access the U tv app
I select the app and it initially opens but then screen goes black and nothing progresses. There is no error code. I can open other apps like Netflix and the iplayer and can stream U on my laptop
I have switched off and disconnected the box and then reconnected and its still the same
Any ideas? Many thanks
3 REPLIES 3
Message 2 of 4
Re: Utv app not opening
Unfortunately the best suggestion at this point would be to use the factory reset option on the TV box. If it's a TV Box Pro then you can select the option to keep recordings.
Message 3 of 4
Thanks. I had read that. Will go ahead and do that and hopefully will sort the problem
Message 4 of 4
Thanks DarrenDev
Have just done the factory reset this morning and app is now working fine.
