Message 1 of 4
What TV box?
My TV box is staring to go on the blink but if you order a new one they just send an old model, what's the latest I can ask for?
3 REPLIES 3
Message 2 of 4
Re: What TV box?
The Box Pro is the standard recording  capable box.   Note requesting a new box and reporting your current  box  faulty/unreliable are likely  to be different  processes.  Which box do you currently  have  ?
Anonymous
Not applicable
Message 3 of 4
Re: What TV box?
Just ring them
Tell them your box isn't working
They will either repair/replace with a new box..pro box
This is one of the benefits of paying a for a subscription service
Message 4 of 4
Re: What TV box?
I have the basic fibre and will try and see if I can request a replacement and that it be the pro box then.
