Message 1 of 2
Where can we get a new remote control?
One button on our remote control only works intermittently.  TV box is working OK.  Can we repair it or can we get a replacement?
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Where can we get a new remote control?
If you have a BT TV subscription then BT should replace it.
If not then Ebay is probably your friend for a reasonably priced replacement.
Intermittent buttons can often be fixed by internal cleaning of the contacts, the hardest part is usually getting them apart! YouTube will probably have a general guide if you feel confident but bear in mind you could also end up with nothing working....
