Message 1 of 12
Why does the EE YOUVIEW Box say some recordings are no longer available with same package
Some recordings on my EE YouView box (it was renamed automatically, not by me) are showing as no longer available but others are fine.
11 REPLIES 11
Message 2 of 12
Re: Why does the EE YOUVIEW Box say some recordings are no longer available with same package
What do you mean when you say your box was renamed?  Are you referring to the EE logo, that was changed 2 years ago?
Which recordings are saying they're no longer available? What channels were they from?
Message 3 of 12
Yes, I have 2 entries for the attached devices. The original YouView one which was last accessed in March 2026 and the EE TV YouView one which was last accessed today. I don't know when it changed but it wasn't by me.
The current problem I have (there have been numerous recordings I have been unable to access in the past) is Alibi HD - Return to Paradise, this has happened for both recordings I have made so far. Other HD channels such as BBC, ITV, Ch4, Ch5 are OK.
I did upgrade my Broadband package to Halo 3 a few months back, I am wondering if this new package altered my TV subscription but this was happening before that (I had previously upgraded to 1Gbps BB last year).
Message 4 of 12
Where are you seeing these entries for attached devices? In your Now TV account maybe? That'd be unrelated to recordings.
Taking one of the recordings you refer to, are you still able to access the channel it was recorded from? If not, then the recording would be blocked too.
Message 5 of 12
Only an observation - Alibi HD recordings (358)  would need a current HD add on to be maintained to view.
Message 6 of 12
Thanks, that is the issue. I cannot watch Alibi HD live but it does allow me to select record from the EPG, is this normal?
Message 7 of 12
It’s the way that it has been set up. You have the flexibility to change your package and add-ons quite often, and the check is made when you come to watch a recording to see if you have the right package/add-on. If your broadband was down at the time that you came to watch a recording you would not be able to as it would not be able to carry out the necessary checks. I believe that most shows from Alibi are available to watch on the NOW app on catch up.
Message 8 of 12
If you don't have the boost add on for hd, you still see the hd channels in the guide, and the box lets you set a recording on those channels without flagging that you don't have access, it's only when you go to play the recording that you get the error notice. I've made that mistake a few times, accidentally recording the wrong version of alibi.
Message 9 of 12
Thanks, BT couldn’t answer my question but the forum has 😎
Message 10 of 12
Best to hide the channels you cannot get using the yellow button. Easier to scroll through the channels in the EPG too.
Richard
