Message 11 of 35
Re: Will and EE TV BOX PRO WORK WITH VODAFONE Home Fibre Connection?
The pro box will show sky content in uhd if you buy now directly and access it through the now app on the pro box.
Message 12 of 35
I didn't think the pro box was UHD compatible for Now???
Message 13 of 35
@DarrenDev ?
Message 14 of 35
No it won't.
@kingleygate
Just in case you weren't aware, IP mode won't work either, so you'll have to use an aerial.
Message 15 of 35
Think people are getting confused with now through EE which isn't allowed access to UHD content, and buying now tv directly and accessing it through the now app on the pro box which shows UHD perfectly .
Any device with access to the now app which is UHD capable will show sky UHD content
Message 16 of 35
Last I knew, NOW hadn't updated the app on the EE TV boxes to support UHD - regardless of subscription type. I can't say definitively that they haven't updated it since. Only someone with a UHD sub could say for sure.
Message 17 of 35
No confusion, I'm afraid you're assertion is simply wrong, as confirmed by Now's list of supported devices.
As @DarrenDev says, the Now app has never supported UHD on the Pro Box & still doesn't. UHD content simply isn't offered
Message 18 of 35
So, are the boxes sold ( as new)on Amazon not strictly legit - these are not via ' marketplace' . There is nothing to suggest that these are not a legitimate product?
Message 19 of 35
@homerhotspur their origin is unknown. But no - they're not legit.  The TV Box Pro has never been offered for sale via any platform - they have only ever been manufactured for the purpose of loaning as part of an BT/EE TV subscription.
Message 20 of 35
Ok, thank you. On another, related, topic, If I decide not to renew my tv subscription, can I buy the existing box off BT if I remain a BB customer?
