Message 21 of 23
Re: Will my BT-TV box stop working if I cancel EETV?
Thanks for the reply. I am not that technically minded unfortunately. I will look into getting a more current Humax/Manhatten box. BT have said they don't need me to return it but I will hang o to it for a bit longer in case they do charge me. After receiving several different answers about whether it needed to be returned, I don't trust them!
Message 22 of 23
@kwaker5  When you say you tried reseting the box  was this by using the maintenance mode screen that is accessible by the buttons on the box. I think there were/are 5 options available from the maintenance mode screen. WHich options did you try ? Did you try both the internet and non internet options ?
Message 23 of 23
I used the buttons on the box but I wasn't able to access the Maintenance mode that was mentioned in the online instructions I found. It just kept cycling between these screens20251208_111401.jpg20251208_111508.jpg20251208_111609.jpg
