Message 11 of 13
Re: YOUVIEW BOX DTR-T2100
@Cliff
BT stopped transferring ownership of YouView boxes to its customers for those supplied after, I think, 19 December 2019. So yours is yours.
Swapping the box through EE TV isn’t applicable, as you don’t have an ongoing contract, but when TalkTalk were doing it for failed owned boxes, they, rather sneakily I thought, retained ownership of the replacement box.
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 12 of 13
Midnight -Voice.
Thanks for the info.i wasn't aware of swapping the box & being out of contract.I've had it long before the date you mention.I've just had to replace my AV receiver so do not want any more expenses at the moment.
I might try fitting a new hard drive seeing as it doesn't really matter if i mess things up.From what i've read the T4000 youview box was the last one & they have now been replaced by the BOX Pro which costs quite a few pennies if haing to buy it.
Thanks again for your help.
Message 13 of 13
Youtube video incorrect. Only need to remove 1 screw from back and 4 from base. Unplug connector to front panel . Remove 2 screws that go through main board to release bottom half of case and then 4 screws that retain hard drive can be backed of enough to release it without removing metal plate altogether.  Refit new drive in reverse order.
Tip. Make sure front panel connector is pushed firmly in or you'll not be able to get box to boot to maintenance mode to initialize reset and new drive recognition process.  As others have said £12 on amazon for new drive. Bargain fix.
