Message 1 of 4
You view box making funny noise
Please help my you view box is only showing 1 blue light and making a funny noise not loading alls it keeps saying is waking up then you view loading. Please can anyone help i have tried resetting and unplugging all the wires turning off waiting and turning back on to no avail.
3 REPLIES 3
Message 2 of 4
Re: You view box making funny noise
@Needadvice72
A funny noise sounds like a failed disc drive, and your other observations are consistent with this.
If you have an EE TV subscription, contact BT/EE for confirmation of this, and to get a replacement.
If you don’t, what box model have you got? Generally, your choices are to replace it with a pre-owned box, from CeX if you want a guarantee, or off eBay if you know how to check an unguaranteed box over the moment it arrives.
Or, if opening the box doesn’t faze you, you could buy a new hard disc - ensure you get a video-rated one - and drop it in. The YouView box will automatically set up the disc, so you don’t need to partition it yourself.
https://ionicindustries.com/repair-guides/bt-youview-box-hard-drive-replacement/#:~:text=Remove%20th....
*** Longtime YouView box owner, Broadband customer (was BT, now EE), finally an EE TV subscriber ***
Message 3 of 4
Thank you i have contacted bt and and had to have a new box sent out.
Message 4 of 4
